fixing the shock mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Nov 4, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i fixed the driver side one (took like 5-6 hours), now i need to fix the passenger side one, it snaped throught the frame.
    what should i do.........weld a new piece of metal to the frame???
    high
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    id surely do some glueing if i was you, just start welding.... its addicting.... you may have a new roll cage before you put the stick down ;->
    Tork DSR
    "Easy killer. That's technology you talk of..."
    http://www.torkpig.homestead.com
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    what about the gas lines
    high
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I got mine welded there too, just keep a fire exstinguisher nearby, and spray water on the tank and lines first
    90K5
  5. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    any one else?????????
    high
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Unless you have a death wish, move the lines. One wrong move and the arc will blow right through the line, and if gas is on the other side, oh boy! Spraying water on the lines is not going to help, the arc don't care and after a few seconds, there won't be enough water left on the lines to even make a difference with splatter.
    This is what I would do. Take the clips loose and get it as far from the frame as possible. Be careful not to crimp it but, the more distance the better. Then wrap a couple of old towels around it. Soak the towels and then keep them wet while working. Of course, keep the extinguisher handy and keep the area clear in case you need to move in a hurry. Make sure there are no fuel leaks or any vapors before starting. Maybe a strong fan blowing away from the weld area (in direction going from weld area toward tank) for a minute or so before starting to clear any vapors, then turn it down low (and maybe move it back a bit) while welding. You don't want the fan blowing your shielding gas away, just gasoline vapors. Always be over cautious when welding anywhere near the tank or fuel lines.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  7. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    would it be just as good to bolt over the hole
    high
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Don't know, depends on how it's done I guess. Sounds like your pretty hard on them though.
    Might want to look into relocating the upper mounts altogether. Lots of people here have built a bar that goes between the rails (like a x-member) and mount the shocks to that. This usually results in the shocks angled in at the top and allows a shorter shock to work with more flex than would normally be possible. Down side is that it provides less control side to side. If you don't need the extra flex, you could always mount it more straight up but eliminate the upper shock mount to the frame (which is a known problem as you have seen).
    Russ
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well i just broke my passanger side mount and all it took is a $6.35 part from kragen's. it is a stud that goes through the frame.
    motormite PN: 31001 (props to Pugsley for the info[​IMG])
    remember mine is a '77. not sure if there is a difference in your late model.
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  10. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    mine broke through the frame though i didn't break the stud......
    high
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    oh...damn, were you skying it or what? [​IMG]
    -Zakk
  12. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    i'm not actually sure why it broke but that was how i broke the driver side one.........damn kids and their trucks
    high
