Flames are no good!
Discussion in 'The Garage' started by RustBuket, Jul 9, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm trying to get my truck to start (which it will...) and when it does, you have to have your foot to the floor and then it starts backfiring and shooting flames out of the headers. I just rebuilt this engine. I know the dist isn't out 180 degrees. There is so much raw fuel in there that after I shut it off the flame continues to burn for a few seconds. HELP!
  2. RustBuket
    Feb 21, 2003
    1,618
    No one knows???? Plz help, I've never done this b4 and my dad doesn't know anything either.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    your timing is way off /forums/images/graemlins/eek.gif
  4. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    timing is way retarded, advance it a bit while idling, shut it off and see if it restarts...get it to the point to where it idles right and will restart without backfiring, then tune it with a vac gauge
  6. rigdonhome
    rigdonhome 1/2 ton status
    May 11, 2003
    252
    HoosierLand
    Agree with the Timing replies.
    However, I think you're giving Fire a bad name. Fire is ALWAYS good, unless it is burning you personally.
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I had this problem while test starting my engine. I had forgotten to hook up the electric choke wire. Once the engine was warm it would die. I would hold it to the floor and crank. All that was doing was filling my headers with gas. Once it would fire...WOOSH! Kinda scary when the tranny cover floorpan is off and you have a 5 gal can of gas on the passenger floorboard (long story, it had no fuel tank yet).
  8. Grim-Reaper
    7,385
    Atlanta
    When you put the timing chain on where both dots facing each other or both up? Facing each other is 180degrees out.
    Your 180 degrees out or you have the firing order wrong.
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Its timing, I promise. Re-Check all timing related components.
    John
  10. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIRE FIIIIIIIIIIIIIIIIIIIIIIIIIIRE! HEH HEH... sorry bout that, I get a little excited... /forums/images/graemlins/wink.gif
  11. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
