Flap, Flap, Flap - Sliding Window Wind Deflector
Discussion in 'The Garage' started by CooknwithGas, May 31, 2002.
  1. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I am in the process if installing slider windows on my 75 blazer top. I noticed that one of the wind deflectors (The little glass piece for deflecting wind) is loose and may flap in the wind.
    Has anyone had problems with these being loose? Need ideas on tightening up the shafts. I don't want to take them off.
    Thanks for the help.
  2. blublaz57
    blublaz57 1/2 ton status
    Feb 2, 2002
    175
    aarizona
    ive got the same problem on my 85 blazer if i figure it out i will let you know don
  3. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    Hey cooknwithgas I repyed to you on the other post long but hopefull helpful, as for the side windows their is a set screw on the side you should be able to tighten it up. I was going to take mine off but I can't get the set screw off. Mine are tight but I get tired of hearing them get hit with trees.
