Flare tool??
Discussion in 'The Garage' started by Masher, Apr 26, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I'm getting ready to plumb the brakes in my 14FF. Does anyone know where to get a flaring tool that is cheap but works well?? ALso what size fittings do I neeed for discs, the Atron brackets use 3/4 ton calipers.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I bought my Double Flare tool from the local auto parts store for about $40. You can sometimes get close enough with all the different lenghts that they offer in hard lines.
  3. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I got mine from a local hardware store in the plumbing department. Same as the one at the Auto parts store. Very Heavy duty $19 total.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you sure that you got a double flare tool? I've only seen single flare tools in the hardware store and they are NOT intended to flare brake line. /forums/images/graemlins/eek.gif A crack can form in the line when using a single flare. /forums/images/graemlins/shocked.gif
  5. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bought my Double Flair (45deg) tool at Pep Boys for about $24 It has worked good...just takes a few times working it to get good at it.
  7. Masher
    Mar 7, 2002
    123
    SW Michigan
    Hey thanks for the replies. Anyone know what size the fittings are on 3/4 ton front calipers??
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Depending on the year, they will either be 7/16 or 10mm.
  9. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    The line fitting should be 3/16 but the wrench size I believe is 7/16
