Flared and O-ring fittings - need adapter
Discussion in 'The Garage' started by crawlink5, Jan 16, 2006.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    I have a flared steering box, flared power steering pump, and an O-Ring hyd brake booster.
    I need to hook up the flared pressure line to the o-ringed hyd booster. Does anyone know of a place to get an adapter?
    If nothing else - the size of these fittings would be great!
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm i duno bout the brake booster, but jimbo sent me the different insert for to convert my oring style to flare. i duno if the same idea would work for it.
  3. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Jimbo? What did the insert go into?
    BTW, I found that I can buy the hose from the pump to the hyd booster.
    But if I buy a hose from the hyd booster to the steering box - well one is flare and one is o-ring. So I'll need an adapter for one end or the other.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    jimbo* is a member on here
  5. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    just get 45 flare nut and reflare end with the new nut. same as brake flare.
  6. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Good idea. Thanks
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
