Flashing E-brake light!!!!
Discussion in 'The Garage' started by Esteban86K5, Jul 4, 2004.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Anyone have any idea what a flashing e-brake light in the dash /forums/images/graemlins/dunno.gif means? It's on a 90 1/2 ton suburban. Thanks in Advance!! /forums/images/graemlins/waytogo.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Does the 90 have rear abs? If so it could be an abs problem or a brake leak. I know my 95 flashed when I had a rear wheel cylinder blow, the sensor in the proportioning valve sensed the pressure loss.
  3. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    Yup, it's the rear wheel ABS computer.
    Count the number of flashes -- should be in the pattern of, for example, eight long ones, then one short one, or somesuch.
    That's code 81, which in my case (1990 V2500 Burb) meant that the computer was burping on one of the solenoid/cylinder things. I fought with it a bit, but ended up unplugging the RWAL computer (black box by the master cylinder and booster.) I figure the brakes are in top notch order and I know how to drive without ABS ... and my (ex)wife is eeping the truck anyway /forums/images/graemlins/histerical.gif
    Post the code here and somebody may be able to look it up. OBTW, you'll want to know which of the two or three KINDS of said computer you have -- mine was the Kelsey Hayes, as evidenced by the KH logo on it, but there are one or two others, IIRC.
    -- A
  4. Esteban86K5
    3,712
    Bakersfield, CA
    Thanks for the info. The Burb belongs to a nighbor of mine so I need to pass the info on and check if the flashes are giving a code of some kind. /forums/images/graemlins/waytogo.gif
