Flat spots in 4.3
Discussion in 'The Garage' started by protechk5, Jul 18, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    In my 2000 s10 with 4.3, 5spd, around 2000-3000rpms there are alot of flat spots in the power band, its pretty bad. Anyone have any ideas??
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Fuel filter
  3. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    on 90's models, that's typical of a failing tps. so, that may be the case on your 2000, also. mine was under $20. backprobe the tps connection as you SLOWLY move the throttle through its full range. if at any point the voltmeter reads out of range, levels out, or spikes, or just acts wierd, the sensor is probably shot. i recommend a battery powered digital multimeter, like mine, for accurate readings.
