Flat style transmission Cross Member?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Jun 12, 2002.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    Can anyone tell me if there is a diffrence in the flat style cross member from say like a 78 and a 84??????? /forums/images/icons/grin.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    They are both the flat style but both look slightly different.
    Both can be used in place of the other with no problems.
    The '85 and newer crossmembers are the double-hump type and are not compatible with the '84 and older flat style.
  3. 78Blazer
    873
    Michigan
    Well I was just out trying to use the 78 flat style on my 84 and the damn thing dont work... the holes dont quite line up right. /forums/images/icons/confused.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not all crossmembers are gonna fit perfectly in place of others. They are not all "one size fits all." Most of them require some coaxing to get them in place, especially if you are not using the original piece. /forums/images/icons/wink.gif
  5. dyeager535
    26,979
    Had the same problem. (70 something crossmember on '81 frame) Holes wouldn't line up.
    Curious, was the older crossmember actually wider or narrower than the '84 frame, or just that the old style crossmember sat further forward or back on the frame than the '84 one did? (as evidenced by the holes already present in the frame)
