flat top knuckle??s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Dec 26, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Okay I have a 10 bolt in the front of my burb. Its out of a 85 Jimmy. I want to do crossover steering, and know I need a flat top knuckle. I found one. Its on a 74 dana 44 axle. I noticed the tie rods are mounted on top instead of on the bottom, so if I get both knuckles and tir rods and center bar am I good, or do I need the spidles and all the outers?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    unless it is a first desing 44 u should be fine .
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You don't want to use the spindles because they will be the old smaller bearing type.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    You will need to use the '74 tie rod because if you use the 10 bolt tie rod, the bottoms of the leaf springs will hit the tie rod and won't allow the turning because of binding when rubbing the tie rod.
    Use the '74 and be done with it. /forums/images/graemlins/wink.gif
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I would, but its on my buddies truck. What were the years it split for designs again, so I can look for a second design.
    Dan
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    First design goes up to '76.
    Second design starts in '77. /forums/images/graemlins/wink.gif
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Okay so I need to find a 77-79 to fit mine. I am going to have to find one now.
    Dan /forums/images/graemlins/burb.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    '76 was the last year for flat top knuckles. /forums/images/graemlins/frown.gif Anything '77 and newer will have no provisions for flat tops.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Cant you just put the newer style spindle on the flat top knuckles? Or is there a difference in bolt pattern?
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm pretty sure they're all the same spindle bolt pattern.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    No differences on the spindles except for the bearing size. Either spindle will work with the other knuckle.
  12. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I found a J20 with flattops, any difference between the jeep 44 and the gm 44 knuckles? Someone is hording all the good parts at the junkyard so I am forced to look at heaps! /forums/images/graemlins/grin.gif
  13. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Okay so the 74 knuckles will bolt right up to my 10 bolt? And I can use everything else from my 10 bolt?
    Dan
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't know about the one you got but My Jeep front D44 has the axle over the springs and the axle width is 4" narrower than the blazer.
    Mine is the wagoneer, the J20 might be a little wider but check it to make sure.
    /forums/images/graemlins/thumb.gif
  15. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    correct me if i am wrong, but you can use just the knuckles....
    and i would use bothe the knuckles off the 74, and i would use the tie rod as well.
    Grant
  16. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats what I am checking on Grant. I believe thats all I need to do, but want to make sure before I tear apart two trucks.
  17. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you will need both knuckles AND the tie rods. the later spindles (76 up) use larger wheel bearings, so you will reuse your spindles. The flat top design stopped in 76. I don't know about jeeps, but I "heard" dodge d44's would work.
