flat top pass side steering knuckle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FastEddy, Apr 19, 2001.
  1. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    Just discovered that 2 of my dana 44 front diffs on the yard (one from 74 blazer, other from 76 3/4ton 4x4) have the flat top pass side steering knuckle (desired for crossover steering) yet went to a friend of mine who has a few and none of his are flat top. are these particularily rare or anything? how much would the knuckle be worth? what type of steering arm could a guy use on it? any input appreciated...Thanks...ED
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think they were on most of the Pre-74 3/4ton P/u's..... A little rare..
    I have seen the knuckles on the net for anywhere from $20ea to $100ea....
    Rockstomper can probably get the arms you need as well as TriCounty Gear....
    Scott at Rockstomper is on the boards and is a great guy. I would start there. The last time I talked to him he said he may have a source for these...
    http://emmett.coloradok5.com[​IMG]
  3. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I think there are more non flat topped knuckles then flat topped. I've machined non-flat topped knuckles into flat top knuckles for a friend of mine with a YJ. Once I have it mounted on the mill it doesn't matter if it's flat topped or not. It only takes a second to mill it flat. Then I can drill and tap it while it's still mounted.
    CB
    <P ID="edit"><FONT SIZE=-1>Edited by azk5 on 04/19/01 08:05 AM (server time).</FONT></P>
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    My 72 has one. Duno if they were on all D44 fer 72 or not??
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  5. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    i recently pulled a pair(you need both to do the conversion) off a 74 jeep wagoneer. this thing had drum brakes, but the spindle bolt patterns are the same. i paid the guy 50 bones for the pair.
    MTPockets
    <A target="_blank" HREF=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</A>
