Flat top question
Discussion in 'The Garage' started by ssped, Nov 19, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I was searching for info on flat tops and cross over steering and of course found everything and more but one tech article stated to get the knuckles in pairs for camber caster. I just grabbed the rt side knuckle only. This is going onto a 10b. Has anyone here replace just one? Dont they make adjustble Ball joints or should I even worry and just run it.
  2. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Also I know ORD makes steering arms but are there any out there under 100$
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    u need to replace both knuckles. the flat top d44 knuckles mount the tie-rod on top or under the 10b knuckles, and the 10b knuckles mount the tie-rod the oposite way, just not sure which one is which way.
  4. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Now that I did not see anywhere in the Tech reports. Thanks.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well im not 100% sure, but im pretty sure. if they arent the opposite, one sits higher than the other or something. i just remember reading that you should replace both at the same time.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes, the D44 tie rod mounts on top, and the 10 bolt mounts underneath.
    http://www.sky-manufacturing.com/ sells a tall and short arm for under $100
  7. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Can I just flip the TRE?
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The taper in the knuckle would be the wrong direction. You could run heims though.
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can also avoid the tierod problem by going with hysteer crossover. The TRE's do mount from the top on a flattop & the bottom on a 10b. With hysteer the tierod is moved up to the steering arms so the problem of only replacing one knuckle is no longer an issue.
    Harley
  10. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Damn skippy. I didnt even think of that and just started adding dollars to the project and making all complicated. OK High steer it is. Thanks that works.
