FLAT TOWING A BLAZER
Discussion in 'The Garage' started by IDGMC, May 10, 2004.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    Hi guys....Long time reader, first time poster. I'm buying a 1979 blazer 400/th400/203t-case. I live in Southern Idaho and its in Jackson, Wy. Long story short It has a bad tranny and I need to tow it home. I have a winch bumper that i'm thinking of mounting on the front of it with a tow bar attached. Then flat towing it behind my friends Durango. Any concearns with this approch? I know the blazer out weights the durango by a bit, but once we get over the passes, its all flat interstate. Should I put the transfer case in neutral or just drop the drive lines?
    Thanks for you help. /forums/images/graemlins/1zhelp.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Your best bet is to get a trailer or at least a tow dolly with some brakes. But if you have to flat tow then I would pull the shafts...
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Yeah well getting up a pass isn't a problem, down is a big one if the durango is lighter than the blazer and you have no brakes back there. Tow dolly at least, I'd flat tow but not for more than a couple miles.
  4. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    [/ QUOTE ] /forums/images/graemlins/waytogo.gif my thoughts exactly! Congrats on the new rig!! /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Dont go over a mountain pass flattowing a Blazer with a Durango /forums/images/graemlins/yikes.gif You will be lucky if you can drive over 25 mph safely on flat ground let along going over a mountain. You will need a tow rig that is the same size or bigger as a minimum or you will not be able to control it at highway speeds.
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    You may want to look into the weight of the Durango vs the Blazer. Those Durangos are pretty heavy actually.
    I towed my K5 (5500lbs) behind my wifes 01 Ram 1500 (6000lbs) about 250 miles one way to a wheeling event and back without any issues. It even snowed on us big time on the way home. I wont say it was a fun trip home, but Ive been in scarier situations. One thing you HAVE to do is: drive like you are towing a heavy load behind you. Dont try to be making up time by driving faster than you should. Dont lose concentration at all. Dont make any sudden steering movements. Anticipate everything... keep your eyes open because a panic stop will probably end up in a wreck.
    My advice is: dont be scared of it, but definately respect it. As for the mountain passes........ I have never driven over them at all, let alone towing, so I wont say anything about that.
    Beyond that... /forums/images/graemlins/smile.gif
    Mike
  7. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Where at in ID are you? Have a cousin who's in-laws are up in blackfoot I think?
    For fuel and a little cash, I could probably make the little road trip and help you out.
  8. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I agree. I flat towed a 79 with 8"+ lift and 38"'s with my '88 using a tow-bar. It was sitting at just a slight angle... The 79 was fairly stripped, so I'm sure it was lighter, but it did get a little hairy on some hills. Other than that, there were moments I almost forgot I was towing it, it stopped really well, and was tight enough not to bang or jerk me around.
