Flat Towing a TJ
Discussion in 'Tow & Trailer' started by BulldogK5, Jan 16, 2007.
  1. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I am trying to find out the best way to flat tow a TJ. A buddy is driving me to pick up my new to me crew cab about 90 miles away. Short of removing the driveshafts, what are some things I need to do. I have read that the jeep should be in the highest gear (5th) with the case in Neutral. Should I tie the shifters into the respective positions? Should I lock the steering wheel or leave it loose? I ask this because people with motorhomes usually leave them loose. If I do this do we leave the key in the on position so that it can't lock or is there another way? It already has a drawbar from a previous owner but he has only used it for short (2-5 miles) trips twice. Thanks for any and all advice.
    Ward
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    The best way is to remove both driveshafts, and leave the steering unlocked.
    second best would be to leave the steering column unlocked, remove the rear shaft, and leave front hubs unlocked with the t-case in neutral.
    anything besides those two options I wouldn't attempt. I pulled my truck with the trans and case in neutral. I wasn't going far. it jumped into gear when I had to stop quick. blew high gear out of the t-case.
  3. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    That's what I thought the answer might be. It would probably be easier to leave things alone and drive the TJ back, huh.:rolleyes:
    Thanks for the input.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I flattowed my K5 several time for a total of around 1500 miles. I pulled the rear driveshaft, left the front hubs unlock, tcase & tranny in neutral, & steering wheel unlocked.
    If it is only 90 miles then that should only be a handful of gallons of gas so I would just drive it to be safe.
    Harley
  5. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Thanks guys. I had him just drive it back.
