Flat towing the Blazer redux: pulling the 14BFF shafts
Discussion in 'The Garage' started by dremu, Feb 28, 2005.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Okay, so let's so I put the Blazer's front up on the dolly, and rather than yanking the U-joint and the driveshaft, I get lazy and pull the shafts out of the 14BFF.
    I mean, they're RIGHT there, I won't even hafta get under the truck, and I'll have the OBA by then and it'd be a snap.
    But, umm, won't all my gear lube come flying out the ends eventually, like won't I need a cover or something?
    Should I just grind down a piece of sheet metal or plate and drill a few holes, or is there a flange gizmo for these pre-made?
    -- A
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    or you could get junkyard axles and cut the ends off,
    me thinks no caps of some sort is a real bad idea
  3. dremu
    Feb 27, 2000
    15,954
    445
    Well, you see why I want to cork them. Never mind the dirt and crap in the bearings :(
    Hmm. Yeah ... but dang, slicing through a 14BFF shaft doesn't sound like fun :(
    -- A
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yes, taking the shafts out will cause you to lose all of your gear oil eventually. I would think just a round metal cover with 8 holes would work. Last time I had my rear shafts out, im pretty sure the end was just flat round metal. Or you could always do what was mentioned above and just buy some junkers and cut the shafts.
    -Harrison
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    Thats what they make sawzalls for. And torches.
    -Harrison
  6. dremu
    Feb 27, 2000
    15,954
    445
    Torch, yes. Sawzall ... eww. Time consuming :D
    So, on the subject, anybody know what 14BFF shafts go for at the PNP or like? (See, Doug, you KNEW you'd get me to buy them eventually :)
    -- A
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    lol, I think you'll spend more time making cover plates than crawling underneith and undoing the 8 u-joint cover bolts and 2 steady bearing bolts (if it even has a steady bearing)
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    It's a Blazer, no steady bearing. Technically he would only have to undo the diff end of the shaft and tie it up out of the way...free to do and only 4 bolts (or nuts)
    Rene
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Ok, now to point out what everyone else has failed to realize or mention. The wheel bearings get their lube from the differential which travels from the carrier to the hubs via the axle shafts. How do you suppose the gear oil is going to get to the hubs if there are no shafts there?
    Why not simply put the T-case in nuetral and tow away? If you're afraid of it jumping into gear then somehow tie it in such a way that it can't jump into gear.
  10. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    Hi, Iused to drive a heavy wrecker for a living. You only need to pull one axle shaft, not both. The idea is to stop the driveline from moving, because most transmission oil pumps are driven by the engine side. Engine not running, no lubrication. AW Direct sells plastic covers for the 14bolt, because they are under most motorhomes and small box trucks. That being said, I`d rather crawl under a truck in a febuary blizzard and undo the driveshaft, than have to mess with the stink of that gear oil. If you have a slip yoke driveshaft, make sure it is tied up REAL TIGHT, or it can bounce out. Good luck on your trip.
  11. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Put the TC in neutral and tow the damn thing. I've done thousands of miles that way with no problems. It ain't rocket science!:waytogo:
  12. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Pulling one shaft only works if you have an open dif. If it's locked you need to pull both shafts.
  13. dyeager535
    26,977
    Isn't the problem with towing a t-case in neutral the same as towing an automatic in neutral? No lubrication, only the output is moving, eventually you end up with a lot of heat in whatever bearing/bushing the output shaft uses.
    Or do the t-cases move enough oil with the output shaft stuff (in neutral) to not have that problem?
  14. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    this works great! Reminds me of a joke we played on my buddy. We pulled his axles out then put just cut ends back in his f/f. he was so mad and confused it was hillarious.
  15. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    :whistle: Now thats just evil.................... ill have find a victim for that some time :saweet:
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not true. An automatic locker will not stay locked with no input torque.
