Flec Pics with 52" Front Springs and Narrowed Body * Added overhead shots *
Discussion in 'The Garage' started by Sandman, Mar 22, 2004.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Flec Pics with 52\" Front Springs and Narrowed Body * Added overhead shots *
    Finally running around. Took some quick pics just to see how everything worked out before it got too dark.
    This was the best I could find locally but I have a few small bugs to work out. Tires fit real fine lock to lock while stuffed. I might even be able to fit some 42" even although it would be tight.
    The 52" front springs give about 4.5" of lift and I have a 1" body lift. Front axle is moved forward about 3.25". I plan on moving the rear back about 2" or so. I just have the room.
    I'm still getting used to the front end.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Re: Flec Pics with 52\" Front Springs and Narrowed Body
    That's some badass tube work! /forums/images/graemlins/bow.gif
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    It looks like a pregnant S-10 body! /forums/images/graemlins/rotfl.gif
    I like it! Looks good! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks! /forums/images/graemlins/thumb.gif
    I seated the bushing bolts in with an impact and havnt backed them off yet and it still flexes pretty good!
    This guy did the fab work:
    CBI OffRoad Fab
    That cage bolts to the floor with more tubes that run through and down to the frame. I'm real happy with the work. Took about a month as the whole thing was basically a custom job. Good price too.
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    simply badass /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    looks awesome!!
  7. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    looks sweet. do you have any close up pics of the front spring hangers and shackles?
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks awesome! Good work Sandman!
  9. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Sweet. Me want my blazer look like that.
  10. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Looks Great! /forums/images/graemlins/waytogo.gifAwsome flex! /forums/images/graemlins/peace.gifI take it that your rig is NOT a dailey driver? If it is, how are you getting buy the fender over the tire laws? /forums/images/graemlins/dunno.gif
    Bill
  11. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    questions....
    on the 3 1/4 with the front axle..
    did you keep the stock centering pin on the 52's?
    did you use a zero rate as well and move it forward.
    /forums/images/graemlins/ears.gif
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ok...
    I'll post some more pics tonight of the front springs and some info of what I did. I'll also post some pics of it juust sitting there as some people have asked.
    I plan on putting plates and insurance back on it and seeing what happens.
    To move the axle forward, The spring swap moves it 2" forward on its own. I also have the spring perches redrilled 1.25" back to move the axle forward again. I ran the redrilled perches in Moab last year with no problems so I decided to stay there. The tire gets real close to the firewall when its stuffed all the way and turned in. 42's might need some clearancing to work all of the way. So basically I am running 5.5" of lift total with full flex on the 40's.
    I have room to move the rear axle back 2" so I am going to work on that next. I might just redrill the perches again, I have not decided yet.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, what is the advantage of moving axles forward(for the front) and backwards (for the rear)? Also, how do you do it. And those springs are from the rear, you put them in the front and they gave you some lift, and moved your axle ahead 2 inches? Sorry, I'm not very smart with this kind of stuff... still learning /forums/images/graemlins/doah.gif
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    No Problem. /forums/images/graemlins/grin.gif
    Moving the front axle forward will give you a better approach angle and will allow you to run a larger tire with less lift. The rear springs are longer than the stock front springs so it is flexier and provides about 4.5" of lift. They are cheap too. Those pics are with the shackles cranked down with an impact gun. To fit the longer springs, You move the front spring mount forward. This in turn moves the axle forward.
    The rear axle going back helps the departure angle and moves the center of gravity forward on the axle giving it some better climbing ablility.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow, thats awesome. I may think about doing that You said stock rear springs give 4.5" of lift up front and move your axle forward. Is there anything else besides the rear springs I need to get this set-up /forums/images/graemlins/laugh.gif
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might want a better rear shackle setup. I already had Off Road Designs Greasable shackels so I drilled out the holes in the lower ends to fit a 9/16 bolts and used some Grade 8, 5" bolts to hold it all together. Instead of using washers to fill in the bushing gap, I cut the ends off of the old bushings and stuffed them in there.
    You will want to go to crossover steering as well as the draglink may not go that short.
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yes, Im planning on cross-over steering as soon as I can get enough money. So thats basically all... I use the rear shackles but drill new holes so they fit in the front and use bolts to hold them up. Thanks, your a good man Sandman /forums/images/graemlins/waytogo.gif
  18. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'll post a bunch of pics tonight. /forums/images/graemlins/grin.gif
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That would be great, /forums/images/graemlins/cool.gif If you dont mind, Im going to save them on file so I can use that as a reference when I do mine /forums/images/graemlins/laugh.gif
  20. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ok, Here are some from the driveway...
