flex fan vs. clutch fan??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, May 26, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    witch do you guys think will do better off road? i like to do rocks and go through water. i have a 19 inch flex fan and the stock 73 clutch fan. i think the clutch in it might be going out. thanx
  2. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    I like the concept of the flex fan............low rpm's the blades are more curved pushing more air,then when the r's increase the blades flatten out and "give back" some horsepower!
    Ron
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i like the low rpm thing but some times i have to go to the higher rpms to get over some rocks or if i'm in a good mode help poeple pull there rigs back onto there rubber. well i can just play around with it. it runs a bit cool anyways.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Hell, if you've already got both, try each one for a while and see which works out better for you.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
    <A target="_blank" HREF=http://www.jarheadsk5.coloradok5.com>http://www.jarheadsk5.coloradok5.com</A>
