Flex lines on the 14B disk conversion
Discussion in 'The Garage' started by FWP, May 17, 2006.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    How long of lines did you use? I can't have a bunch of brake line hanging out to catch on rocks. It has to be tight and neat. Off the shelf parts stock numbers would be great too. Did you cut the ends of the hard line and re-flare, or how did you approach it? TIA
  2. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I could not tell you the exact length of mine, maybe 12 inches, perfect to make a loop that stays up out of the way. NAPA part number is 4136832. Also want to add I made a bracket that I welded to the axle and used a brake hose clip to secure it. I also bought some new brake line, cut it and flared it so it was a custom fit.
  3. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    No hard lines here. I went with braided to the block. Makes nice for trail repair 1 spare will work front or rear....
  4. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    Braided Stainless hose 8"
  5. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i thought the bleeder was supposed to face upwards?
  6. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Fred, I used lines for a '79 Chevette as per directions from GrimReaper, they're 10" long, sorry, can't find the number. I ran hard line under the springs (but high up on the axle) to a home-made bracket (bolted to one of the bolts that hold the caliper bracket) so that the end of the hard line pointed forward. Installed the rubber line and looped it back to the (Caddy) caliper. Everything but my e-brake cable and bracket is above the axle. But I like Toby's solution of braided line to the block.
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I used the chevette lines also. Cheap and they work great.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I used 78 K20 front lines. About 10" long. They are above the tube havent had any issues catching them on anything yet.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I used K20 front lines too. Welded a couple of spare brake line brackets to the tube and curled the lines under the springs. They're high enough that they'll never catch on anything.
    Rene
  10. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    how about the ones off the front of my blazer. they are free!
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    All great ideas, thanks guys!
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I used 8" stainless steel lines from TSM manufacturing.
  13. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    They are. But if you put your right caliper on the left, and your left caliper on the right, then they end up upside-down. But if you look in the background, you see e-brake linkage. He had to mount the calipers like that to keep the e-brake stuff out of the way. He probably has to take the calipers off the mount to get them to bleed now, but that's the price you pay for caddy calipers.
    And for lines, I too am using some freebies. Leftovers from an S10 project we had going on here.
  14. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Those are the ones I use as well.
