flex plate and engine running
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Apr 1, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    if i have my transmission and torque converter removed, is it ok for me to start and run my engine to watch my flex plate and ensure that it does not have any "wobble" to it?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i dont see why it would hurt.. thats how it runs on an engine stand i think..
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive done it before, when i had my tranny out and exhaust off (headers) /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yes, its fine, stay away from the flexplate though
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Most definitely... Be carefull dude, that thing could rip you a new one /forums/images/graemlins/eek.gif
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah, we started a 350 on the stand with nothing attached. No flexplate, exhaust (open valves /forums/images/graemlins/shocked.gif) just for a second to see if it ran OK. I was standing in front of it and the fan pulley flew off and went between my legs. Missed the twins by .0001"
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    how did you start it will no flex plate? /forums/images/graemlins/thinking.gif
    that musta freaked you out /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Do you have an engine mount that I don't?? Secure the motor well or you'll bust/bend the distributer! /forums/images/graemlins/thumb.gif
  9. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Take all the precautions you can think of and DO NOT get rev happy . Your motor will rev FASTER than ever before due to lack of converter weight. Beacareful not to kill your motor by over reving of reving to quickly !
    Tom
  10. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    What are you supporting the rear of the engine with when the tranny is out? Why not just remove the flexplate and check it for warp, by laying it down on a flat surface, or just replace it all together. /forums/images/graemlins/thinking.gif
  11. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    I would not recommend you do that....take the plate off and check it if there is any question....also how is the back of the engine supported..???
  12. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    a couple of you are asking how i am supporting the rear of the engine... i am not sure yet. my tranny install instructions state that i need to support the rear but tell me not to place a support under the oil pan. there are a few areas that i can get a bottle jack into but this will not work if i am going to run it to observe the flex plate. at first, i did not realize how inexpensive the flex plate was (35 to 45 bones). i am working with a 95 crate motor; if the flex plate looks flaky in anyway, i am just going to replace it.
  13. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    /forums/images/graemlins/doah.gif I don't know why I said that. /forums/images/graemlins/doah.gif Flexplate was indeed on, but nothing else was. And yes, it was very freaky, and my dad and neighbor pissing their pants laughing didn't make it any better. /forums/images/graemlins/yikes.gif
  14. dave_90_blazer
    Jan 1, 2004
    688
    you can support it under the oil pan, but use a block of wood(2x4/2x6, ect.) on top of the jack to spread the load
