Flex plate issue
Discussion in 'The Garage' started by Russell, Feb 11, 2005.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    342
    Fort McMurray, Alberta
    Man, murphey certainly loves to bother me :P
    I'm trying to install my flexplate onto my 355 so I can break it in tommorow, but when I stick the flex plate bolts in, they hit the back of the block!
    I just pulled these bolts out of this engine maybe a month ago, and they fit real good then... The engine has been sitting on an engine stand, and has not been dropped or anything. I never touched the lower rotating assembly, just put a new cam in, and valve seals.
    Any ideas?
  2. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    Ghosts??
    Maybe a ghost swapped bolts when you weren't looking?:rotfl: --Are you sure you put the same bolts in that you removed??--did the lockwashers fall off?? Is it a new flexplate??--if not,I dont know what to tell you,unless your shop is haunted or the bolts stretched themselves longer all by themselves,you have a real mystery on your hands!--I hope its not due too excessive endlay in the crankshaft,if thats the case its time for new main bearings,or at least the one in the back that takes up the thrust..good luck..:crazy:
  3. ss396
    ss396 Registered Member
    Jan 20, 2004
    29
    Puyallup/Sumner Area WA
    Are you talking about the crankshaft bolts or the torque convertor bolts?
    Flywheel bolts will be longer than flexplate bolts on the crank, maybe you are using the wrong ones?
    For torque convertors, I believe the flexplate can only go on one way. There are indentations on the flexplate where the convertor bolts to. If it's in the wrong way then the bolt heads may hit the block.
  4. Russell
    Jun 23, 2000
    7,927
    342
    Bingo. I stuck the shorter style bolts onto my Chevy's flywheel... So I spent the afternoon trying to find a new set, but absolutely no one had them in stock.
    I had another 355 I pulled the flex plate off of a while back, so I may still have them kicking around somewhere. Thats my only hope, unless I can hacksaw em...
