flex plate to torque converter?
Discussion in 'The Garage' started by 13lazer, Oct 10, 2005.
  1. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i cant remember but is there a special 3/8" bolt used between a small block flex plate and the th350 torque converter. A shoulder bolt or a different hex head. I cant believe the trouble im having lining these up right now. I dont recognize anything in my hardware pile either.
    Thanx
    aaron
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Moved to garage to get your more responses. :waytogo:
  3. jeff101
    jeff101 Registered Member
    May 1, 2004
    24
    Lander,Wyoming
    I am not sure if there is a special bolt for that or not.
    I just used 3/8" x 1" grade 8 bolt and nuts with no lock washer or anything and have not had any probs. with them loosening.
    JEFF
  4. bayou blazer
    bayou blazer 1/2 ton status
    Jul 16, 2004
    176
    la
    ARP makes a specific bolt set for that application through Summit Racing
    ARP bolts
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are fine thread , and used a 9/16 wrench to remove .
    I don't have one in front of me at the moment , but I just yanked the motor off the th350 in the Chevelle , and could look at em when I get home .
  6. diesel4me
    Jul 24, 2003
    17,567
    942
    Massachussetts
    Depends...
    If its a nut and bolt style,I just use grade 8 bolts and nuts with some locktite..about an inch long..never had one fail yet..
    If they thread into the converter,they are usually metric,and are special bolts..I've seen them on the "Dorman" rack at parts stores--I think the "HELP" rack has them too.(I heard Dorman sold out to Motormite Co,who makes the "HELP" stuff....another old time company bites the dust.. :blush: :doah: ..
  7. piletender29
    piletender29 Newbie
    Oct 17, 2005
    Las Vegas
    Just thoughtiwouldshare some info on your problem..ARP sells a set of bolts that work very well and also make sure that the converter is a three lug mount and not a four lug if so they gave you the wrong converter and also check to see if you have two different sets of mounting holes in the flex plate. this should help as i have run into this problem before godd luck
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    *buzzer sound* The flexplate to crank bolts are fine thread...Torque converter bolts are course thread. They are just shouldered bolts. I even found some in a kit from Spectra at Auto Zone.
  9. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    stock they are weird but i replaced minr with gr8's and doing fine
    replacement ones were $18, napa grd8's were $2
  10. 13lazer
    Dec 30, 2004
    115
    San Pedro, CA
    its up and running
    i figured i would be upgrading to a 700r4 soon so i just muscled three 3/4" long ARP header bolts in there. They threaded into the torque converter. The reply on here about metric threads sounds like the problem i had, i never put in so much effort on a 3/8" coarse thread bolt in my life. Those bolts will never back out, i'm sure of that.
    i really want to know the motive of the general motors engineer who decided on the random placement of metric bolts in American cars. What were they thinking?!
