Flex questions...PICS
Discussion in 'The Garage' started by MTBLAZER89, Oct 28, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So I flexed my truck today and found a few issues. Wonder what you guys think? It's not massive flex or anything, but I am looking into the 52 swap, and I think that will amplify these problems. Flex Pics
    Here are the issues I have:
    Pitman arm.. Superlift #1104, and Superlift 4" springs so they are not real flexy, but they come awful close to the arm. How do you get around this problem with a flexier spring? Is this just the maximum amount of uptravel one can achieve.
    Draglink...This was the first time I have noticed this problem. I have the Sky arm with a 1" spacer under it. It clears fine all the time until I stuff the driver side I guess /forums/images/graemlins/dunno.gif Don't know about solving this either.
    This is the pass side spring. Will this get worse with more droop with the 52's?
    This is how it sits at ride heigth. There is about an inch and a half of clearance between the Draglink and pass spring.
    Thanks for any advice you guys can give me /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    #1 bumpstop your up travel to keep the springs out of negative arch. This will keep you from destroying springs and keep your pitman arm away from them.
    #2, get rid of your zero rates. Some people can't run zero rates with crossover, there just isn't enough clearance for the majority. You're one of them unforunately.
    That's how I see it anyway. Of course the bumpstops may be enough to solve both problems. /forums/images/graemlins/thumb.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'll add one to tims list... 1/2"-1" passengers side arm spacer
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    He already has one.
    Harley
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He already has one.
    Harley
    Exactly. /forums/images/graemlins/thumb.gif
    Oh and just so I don't make a post without a product plug, Daystar makes some bad ass bumpstops. /forums/images/graemlins/thumb.gif
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I say get rid of the zero rates and you should be pretty good. /forums/images/graemlins/thumb.gif
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    how many springs come on the 52 inch pack? my 4 inch TC lift has 3 springs, do you think less springs might help with the problem?
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The 52's cpoe either with 4 springs and the overload or 5 springs and the overload depending which ones you get /forums/images/graemlins/thumb.gif
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I would get rid of the zero-rates, but nobody makes a 5" spring /forums/images/graemlins/dunno.gif and I need the clearance. So what would be the benefit of the 52's if I have achieved maximum up travel? Do they droop significantly better? The draglink on the pass spring is barley touching so not a huge prob, but I was just worried about the pitman arm. I don't think it will make contact cause my shocks will stop it first, but towers are coming soon. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Throw some bumpstops on there and flex it out again. I'd be willing to bet that it'd work out real well.
    6" springs and moving that zero rate to the rear is always an option too.
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I already have a 0-rate in the rear with 4" superlift springs...Yeah lift springs /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif I'll look into some bumpstops and see /forums/images/graemlins/dunno.gif
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'll third or fourth bumpstops. Negative arch is one of the big killers of leaf springs. Will keep you away from the steering arm as well. 52s droop a ton, thats one of their big advantages. I'd lose the zero rate as well. From what I've heard 52s are a little more than 4" of lift so that could work for you. Have a 1" body lift? Its a decent option.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How about taking ALL the zero rates out and putting in a 1" body lift then, if the bumpstop idea fails.
  14. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    He already has one.
    Harley
    /forums/images/graemlins/doah.gif
  15. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    well I will start with the bumpstops and go from there. This is max travel onn my truck right now. If I do the 52's we'll see how much I get from them then maybe look at the 1" body lift from there. Thanks guys.
    PS anybody else with a similar set up to mine got any similar flex pics to compare?? Harley maybe.. /forums/images/graemlins/waytogo.gif
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool anybody else /forums/images/graemlins/waytogo.gif
  18. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    This was my prob with flex
  19. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    What's that?? rubbin??
  20. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    any other pics?
