Flex vs. traction bars
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Feb 25, 2001.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    If I install traction bars how much will this affect flex. I am not an avid rock crawler more sand, dirt/mud, & snow.
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    i wouldnt worry of you are not doing any major rockcrawling. RESPECT MY ATHAURITAY!
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>
    <font color=red>SIGN MY GUESTBOOK!</font color=red>
    <P ID="edit"><FONT SIZE=-1>Edited by shaggyk5 on 02/25/01 07:57 PM (server time).</FONT></P>
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks man.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You can make traction bars that will not eliminate flex. Get some weld-on brakets and some heim joints from a circle track suply store, then some DOM tubing. Attatch the links from the axle to the frame, and they will eliminate axle wrap. Heim joints will allow the trac bars to twist so flex wont be effected.</font color=blue>
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Or, make a torque arm type of traction bar, which is basically a normal traction bar, connected to the axle in the normal way. The difference is that it connects to the frame through a second link, which has a joint at both ends. It should be set up so that this link is straight up and down when the vehicle is level and at rest.
    This prevents twisting of the axle tube, but allows it to travel through a large range of motion.
    <font color=blue>"We have to take seriously the role in this problem of older men who prey on underage women..." Bill Clinton, 1996.</font color=blue>
