Flexed my K20 in a ditch *PICS*
Discussion in 'The Garage' started by ugly_blazer, Aug 22, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    No rocks here, just a little ditch (ya gotta work with what ya have). Do others cabs and beds go this crazy? The bed has dented the back of the cab where it hits.
    This one shows the angle difference between the front and rear axle
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    yikes! that bed is diong some major running away... besides that... nice pics... another picture for my desktop /forums/images/graemlins/cool.gif
  3. ugly_blazer
    Apr 12, 2004
    1,214
    Thanks /forums/images/graemlins/thumb.gif I've been working on it since I got it 10 months ago and this is the first thing I've done with it (other than mudding 1 time with the last tranny/tcase, but they broke). The front needs some longer shackles, the spring mashed the frame pretty good /forums/images/graemlins/blush.gif
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    WOW, pretty flexy! /forums/images/graemlins/peace.gif
  5. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    Not only is your suspension flexing, so is your frame.
  6. ugly_blazer
    Apr 12, 2004
    1,214
    But is this good or bad or neither? /forums/images/graemlins/dunno.gif
  7. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I would say "bad", but your frame is no different than anybody elses. It just makes the rivets in a frame a little looser.
  8. ugly_blazer
    Apr 12, 2004
    1,214
    Maybe I'll stay out of the ditches and in the mud... /forums/images/graemlins/blush.gif
  9. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    I had a 78 K10 p/u, and the frame flexed pretty much the same (didn't have much susp flex) so I wasn't shocked to the bed/cab angle difference, just not quite THAT much...I'd think too much could damage motor & tranny mounts...or bust the frame (crack)
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Does the thing have a body lift? They seem to exagerate the flex. That thing looks way more flexed out than it should be, is the bed bolted in tight and everything?
  11. ugly_blazer
    Apr 12, 2004
    1,214
    Yep, 3" body lift. The cab still has the original rubber mounts from '79. The bed is very rusty, it uses all 4 mounting holes in the front section but only 2 in the rear, they are tight though.
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Nature of the beast /forums/images/graemlins/grin.gif
    You can't keep that length of frame rigid - especially when the body is two separate pieces, and no jungle-gym.
    Old Fords did this as well... and they get scars on the back of the cab (from the box) to prove it! /forums/images/graemlins/rotfl.gif
  13. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I had a Crew Cab K-3500 ( GMC ) that flexed WAAAAY to much when crossing ruts while off road - people would always ask me how the dents got on the back of the cab and when I told them that it was from the bed they could not believe that it would flex that much ...... /forums/images/graemlins/thumb.gif
    I called them off road battle scars .
    If you flex it enough times like that you will never see your body lines match up again /forums/images/graemlins/rotfl.gif /forums/images/graemlins/waytogo.gif.
    Tom
  14. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I have the same truck besides being a 1973. My bed does not flex anywhere near that much. If your suspension is designed to flex; I wouldn't think the bed would have to move that much. /forums/images/graemlins/dunno.gif
  15. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif i have never seen the two move THAT much, i think you need a cab mount or 4. body lifts do exagurate the flex, but that is still alot.
    nice flex. /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  16. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I think you put in some crossmembers /forums/images/graemlins/weld.gif Then you should see if it makes a difference when you get your flex on.
    Later
  17. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    The body lift makes a huge difference...when I had a 3" with the stock rubber mounts the body flexed a lot, with no body lift and and poly mounts it is MUCH better! The leverage the bolts have squeeze the sh!t out of the rubber mounts /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
  18. ugly_blazer
    Apr 12, 2004
    1,214
    I had it in the ditch again today, and the stock rubber mounts do smash quite a bit. The back cab mounts are about 3" tall and while flexing one side is smashed almost completly flat.
    Also went muddin' today in the swamp /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    woah! looks fun /forums/images/graemlins/peace.gif
  20. ugly_blazer
    Apr 12, 2004
    1,214
    Ya it was alot of fun. Not bad for Ground Hawgs considering someone( /forums/images/graemlins/screwy.gif) on this forum says they suck... /forums/images/graemlins/rotfl.gif
