flexed the sub for the first time since the body lift. UH OH!
Discussion in 'The Garage' started by muddysub, Nov 29, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    is this supposed to happen? i don't think so. /forums/images/graemlins/frown.gif they were tight but this happened. why? /forums/images/graemlins/confused.gif
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ur ganna have to check that link again...
  3. muddysub
    Jun 23, 2001
    10,452
    489
    try that. if that don't work it's the last shot in my misc album in my webshot.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Log out first /forums/images/graemlins/rolleyes.gif
    Or post your IP /forums/images/graemlins/thumb.gif
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Still no gouda. /forums/images/graemlins/confused.gif
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    MY P/U used to do the same thing before i replaced the body mounts . what is happening is that since the body is so heavy and plus all froce from being flxed out it is trying to pull the rubber through the bolt hole .the bottom mount is getting squished flatter than , umm something really flat haha . get poly ones .
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Mine used to do the same thing when I had a body lift. They are inheritly evil and are only designed for lift. Not for a true trail rig IMHO. I dumped my body lift and I haven't had trouble since. The damn thing just cause the body to have so much flex under those conditions.
  9. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Looks like its squishing the bottom part of the body mount flat. Did you replace the body mounts when you did the lift, or reuse the stock ones?
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I noticed the same thing after my body lift. Poly mounts are in the mail....
  11. muddysub
    Jun 23, 2001
    10,452
    489
    i kept the old ones ( i know, i know) but it did this before the body lift too but it's just worse now. /forums/images/graemlins/confused.gif would polys fix this?
  12. nofeartruckin00
    Oct 5, 2001
    798
    If it is the mounts squishing down, then yes, the poly's won't squish like the rubber ones.
  13. muddysub
    Jun 23, 2001
    10,452
    489
    hmmmm how do i order a set of polys without my dad knowing? i use my buddy's card to order them from his house tomorrow! /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif hehehehehe
  14. nofeartruckin00
    Oct 5, 2001
    798
    If he asks, just show him the picture. "See, my old mounts are broken, i need new ones!" /forums/images/graemlins/thumb.gif
  15. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    hehe, thats the oldest trick in the book to get somebody to let you buy something new... break it, then you have to buy new stuff /forums/images/graemlins/thumb.gif
  16. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i put a body lift one my p/u when i put on the poly mounts , i made the b/l myself but i accidentaly made it 3/4 instead of 1 inch hahaha . probly for the better tho . doesnt seem to affect much really . p/u and k5s are a lot different on the trail since the cab and bed flex seperatley . my truck is a noodle compared to a k5/sub . /forums/images/graemlins/thumb.gif
  17. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I pulled the nut through the bottom spacer on the body mounts when I was flexing the burb last year...I assume it'll only get worse with that 3" body lift that's in the mail... /forums/images/graemlins/burb.gif
  18. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I still have no complaints about my bodylift. So far it's done a great job of keeping the body off the 38's. I did the Energy Suspension body mounts the same time I did the body lift.
  19. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    That is fairly common. I have pulled that bolt through both sides of my core support. Now after much beefing and welding on the core support I trash the rubbers about every other season. But then I am really hard on mine flex wise. I like the chest high boulders. As long as a burb is I would think that is normal. If you put poly on it you will most likely start to wrinkle fenders and inner fenders if you continue to flex it hard. I just put big washers on top and bottom of mine and call it good. Just dont look at it when it flexes and you will have more peace of mind /forums/images/graemlins/grin.gif
