Flexiest front springs? Who makes them?
Discussion in 'The Garage' started by Mudbug1979, Dec 14, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Ok, I'm finally getting the ole girl where I think she needs to be for a multipurpose vehicle. My question isk, Who makes the flexiest front springs for the K5? I have some pro comps on it now and they are the 4" lift ones. I have extended shackles on the rear of the springs but If I have to remove them I would like to have some around the 6" lift range. I will keep the Shackles and run 4" springs if that will help it flex. I need some suggestions on these please.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    52's and a zero-rate...
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    out of the box would be tough country or bds. custom would be deaver or alcan
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Add National to that custom list.
  5. Mudbug1979
    Aug 4, 2002
    439
    OK, I have seen the posts for the 52 inch springs. Are these the one's from the 2wd f-150? If so, what years do I need to look for? How do they handle on the highway? I have no sway bar connected, and I don't mind a little sway at hwy speeds but I don't want it to be crazy. I'm just not real clear on the advantages of doing this. Thanks for all the info. I'm still searching while I'm posting so it's not like I'm not trying.
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    52's are stock, 52" long rear chevy springs. You could just pull them out of the back of your k5.
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    52's by far are the best spring for the front that I have seen so far.
  8. Mudbug1979
    Aug 4, 2002
    439
    52" Rear springs
    Now the stock springs equal how much lift? Will any of them work from a 4wd truck/blazer/suburban any years? Thanks again for all the info.
  9. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Mine came out of an 85 K5. All K5's should have 52's in the rear, and I think most 1/2 ton P/U's have them... some will have 56's, so take your tape measure.
    The Ford springs you mentioned are 57's out of a 2wd F150, and they ride great on the highway, but too soft if you haul/tow much.
  10. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Whoa, sorry to steal the thread. You can take rear springs from a K5 and mount them up front for like 4" of lift?!??!
  11. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    my swap gave me 5"s of lift, i had to pull the zero rate so it would sit level, in the back i have a ORD 4" shackle flip and zero rate
  12. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Basically, yes. And you also get 2" of axle movement.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    :lol: where have you been?
  14. Mudbug1979
    Aug 4, 2002
    439
    Axle Movement?
    What do you mean by Axle Movement? Still sort of a newbie so sorry for the ignorant questions. So, the factory rear leafs will get me around 4-5" of lift right? Do I need to reverse them when I install them or just take them straight out of the back and put them in the front like they come out? Thanks again.
  15. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    the ecnter pin is in the middle of the springs so it does not matter whihch way you put them.
    I springs will move your axle 2" forward.
    Check out the search, there are alot of posts about this.
  16. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You will need to move the front mount forward too before you move springs. There is a ton of info out here on the swap, and PM me if you have any questions.
    It will work, it will lift, and they are flexy...
  17. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    What are you guys running for driveshafts with that kind of travel? My stock CV had to be ground just to clear at ride hight after a doubler (I only have 5" of lift also).
  18. zcarczar
    Feb 10, 2002
    2,495
    im running a stock shaft with a ground CV with a clocked NP241, I still max out the CV at full droop.
  19. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    More problems are being found in thw amount of driveshaft slip, rather than the driveshaft angle.
