Flexplate and TC torque specs?
Discussion in 'The Garage' started by shupach, Jan 12, 2004.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    wat do i torque the flexplate bolts and TC bolts down too? i thought it was 60 for the flexplate, and now after runnin the motor a bit the flexplate is loose again, and so are the TC bolts.
    im gonna try to get this stuff done before i leave tomorrow so any posts tonite would be great.
    thanks,
    phill
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    did you use loctite?? i would think the torque convertor bolts would be 60 and the flexplate would be higher.. say around 90-120?
  3. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    Torque according to Chiltons
    Flywheel 60 lbs
    Torque converter 50 lbs
