flexplate/flywheel thing is slipping on the torque converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Jun 3, 2003.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    why would it be doing this, it just started doing it and when i installed the engine i made sure it was tight and all. anyone have any ideas?
    phill
  2. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    the only way this could happen is if you forgot to put the 3 bolts in that hold the engine side of the torque converter to the flywheel.
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    nope they're on, im gonna check all three later, only one was exposed when i saw it.
    phill
  4. dyeager535
    26,982
    191
    I don't quite understand what you are trying to say, but the flexplate is physically attached to both the engine and transmission via bolts. If something is "slipping", its broken. If the ring gear and torque converter aren't turning (or not at the same speed) as the engine, then the flexplate is probably broken all the way around the inside somewhere.
    Usually doesn't get THAT bad, but I have seen it happen before.
  5. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    yeah....umm....sounds like the flexplate has sheared itself into two pieces around the crank bolt circle, but even then it should be turning at the same speed as the torque converter. I can't think of a way the visible part of the flexplate and the torque converter could be traveling at different speeds as long as the 3 bolts are in.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    can you start it up and drive it? is it the flywheel and the torque converter that are turning different speeds then each-other? if it is the flywheel and the torque converter that are turning at different speeds then with all three bolts in there is now way they can turn at different speeds. is it making any noise?
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I second that!
  8. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    thats what happened to mine . my flexplate broke right
    around where it bolts to the crank.
  9. shupach
    Dec 28, 2000
    648
    Dallas, TX
    the flexplate seems fine, it wont budge, the torque convertor has just a little wiggle like its not completely secured to the flexplate, man i hope i didnt snap the flexplate, just put the new engine in.
    phill
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    phill
    If the flexplate is not broken and that has happened to me before just around the crank bolts, it could be the tranny pump tabs that broke inside the tranny, Also happened to me on the same car /forums/images/graemlins/mad.gif.
    It should make some kind of noise though either way it's not going to slip but skip and you should hear it.
    I am assuming that it isn't running or you wouldn't have noticed right?
    /forums/images/graemlins/thumb.gif
  11. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Be sure to use some locktite on the torque convertor to flywheel bolts... I once made the mistake of NOT using any, and it really does make a horendous noise! /forums/images/graemlins/eek.gif If the torque convertor has slight play, I would check pull all three torque convertor to flywheel bolts, locktite them, and reinstall.
    Hope this helps...
    -Dan
