Flexplate for a 292 I6
Discussion in 'Parts & Trucks Wanted' started by afroman006, Nov 17, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Hey I am puttin a 292 on a TH400 and need a flexplate. It originally was attached to a SM465. I'm prety sure this is what I need. Thx
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I might have one - I'll have to check the 292 parts pile . It might take me a few days so if I do not respond send me a PM and remind me .
    Just FYI you could make a SBC flexplate work - just drill the holes out the the larger shank size and add additional holes for the extra dowl pins - the 292 is internally balance just like the SBC's .
    Tom
  3. afroman006
    Aug 21, 2002
    2,876
    Well thx for the info but I'd rather not ghetto rig if I dont have to lol. If you could look and get back to me I'd appreciate it. Thx
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have used late 60s early 70s 350 flywheel and stuff on a 64 model 292 engine and never had to drill anything, worked great, watch which starter bolt pattern you have on the 292 though, you may be stuck iwth only one bolt pattern and therefore be only able to use one diameter wheel/plate
    staggered pattern for 14" wheel/plate
    straight pattern for 12" wheel/plate
    80-up 305 4bbl engines(LG4 and L69 caprices camaros firebirds etc are great source for 12.5" wheels and starters
    or if you have manual trans then you use 14" wheel and cat iron three bolt starter nose, if the bellhousing is the original cast iron 72 older style one
  5. afroman006
    Aug 21, 2002
    2,876
    So you're saying that anyone off those engines will work? My 292 is an 80 if it matters. It sounded like you were recomending the one off the 305 though, is that correct? Thx
  6. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    FWIW, Tom's "ghetto fix" was done by a machine shop. /forums/images/graemlins/whistling.gif
  7. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Just to set things straight - the early years 292's did not have the additional dowel holes but your 1980 model 292 will most definetely have them so a SBC flexplate will have to be modified to work . BUT , as luck would have it I do have a 292 flexplate along with the special retaining bolts and the center retention ring that came on O.E.M. 292's .
    Send me ten bucks to cover freight and I'll ship it to Ya . I have absolutely no plans on ever putting a TH400 in my Blazer so it will just sit on the shelf forever -I would rather see someone get some use out of it .
    Tom
    /forums/images/graemlins/thumb.gif
  8. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I like to call it "Professional Ghetto Fabing" /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Tom
  9. afroman006
    Aug 21, 2002
    2,876
    Awsome PM your address please. Will you take a personal check? Thx
  10. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    It's all good ! PM sent .
    Tom
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I got your address and all in the mail today - I will get get the parts off of my spare motor this weekend and ship them out soon after that .
    Tom /forums/images/graemlins/thumb.gif
