Flexplate Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by along4, Jul 11, 2002.
  1. along4
    along4 Registered Member
    Jan 1, 2002
    25
    Prescott, AZ
    I just pulled a TH350 out of my truck that had a torque converter with 3 bolts. Does anyone know if the converter that will come with my 700r4 will have a 3 or 4 bolt pattern? Know where I can get a cheap flexplate for the 700r4? Thanks.
  2. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I believe they use the same flexplate? I bought a new flexplate at autozone for like $16.00. They aren't expensive unless you want to get an aluminum one.
  3. dyeager535
    26,982
    191
    I was under the impression they were either 3 or 6 bolts, and thats it. I believe most, if not all GM flexplates are setup for either "pattern". Unless someone says differently of course : )
  4. along4
    Jan 1, 2002
    25
    Prescott, AZ
    There are 6 holes in the flexplate, so maybe I can use it. Thanks.
  5. dyeager535
    26,982
    191
    Just make sure to check all bolt holes (both for the crank and the converter) for cracks, as they tend to after awhile, and it starts with cracks radiating from any of the holes in the flexplate.
    As was suggested, it may be a wise choice to buy a new one now and hopefully avoid the problem for a long time, instead of putting a used one in your vehicle that *may* crack in a relatively short period of time, especially if they are $16 cheap (wow) Last flexplate I pulled out of a GM vehicle was warped pretty badly.
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    the only diff I know is the 400 sbc is extrenally balanced and has a weight on it and notch like a big block I think. Desiels hever the 6 bolt as far as I know.... but then again, I may be wrong
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It should be fine. I have done this conversion and did not have to change the flexplate.
