Flexplate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Sep 14, 2004.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Need to replace my flexplate. What is the easiet/quickest way to get to it out and back in. Do I have to completely drop the trans?
    AW
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Nope, you don't have to completely remove the tranny. I've replace mine 5 time in the last 2 yrs(recent one has held up for 9 months not /forums/images/graemlins/thumb.gif ), but all you have to do is move the tranny/tcase back far enough to get to the bolts and be able to remove it. Then just slide the tranny/tcase back up and bolt er back together /forums/images/graemlins/thumb.gif
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I don't have a tranny jack. Do I need to get one, or can I just use some 2x4s and let is rest on the cross members. Do I need to disconnect everything from the trans and case or is there enough slack?
    AW
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    As far as a jack, use whatever you can find that is STABLE enough to hold it in place long enough to do it. I used an ATV stand when I did mine(I don't own a tranny jack either).
    Disconnect both driveshafts, vacuum modulator, kick-down cable, tranny lines /forums/images/graemlins/dunno.gif(depends on slack)tranny linkage, maybe the tcase shifter arm thru the floor. I think that is all i had to do. Been about a yr since the last time I did it.
