Flickering Headlights
Discussion in 'The Garage' started by tripnz, Oct 7, 2004.
  1. tripnz
    tripnz Newbie
    Oct 7, 2004
    I have 88 Chev K5 Silverado. Last night on my way home my headlights began flickering Dim, normal, dim ..... you get the idea. I suspect a short in the harness, but this is a new area for me. Anyone have any thoughts on what I should check?
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I would start by checking the ground wires. Each connector should have a ground wire coming out of it. I had this problem the other night. The wires can come loose in the connector.
  3. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    Could be a bad alternator.
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Similar thing happened to me one night, they flashed a few times then went out completely. Check your wires at the starter, They may be burnt and hanging by a thread or loose.
    Ken
  5. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I had the same problem a couple of years back and it ended up being a faulty or inexistant ground. I didn't ground the engine to the frame when I swapped motors. The lights flickered because the motor would intermitently contact the frame and ground itself. Took me a couple of days to figure the very simple fix.
