flip kit and shocks?
Discussion in 'OffRoad Design' started by dmoney, Mar 8, 2007.
  1. dmoney
    dmoney 1/2 ton status
    Jan 21, 2007
    119
    Silverhill, Al.
    if I go with the ord flip kit in the rear do I need longer shocks? I have a 6 inch lift on it now and it came with new shocks so I dont want to replace if I dont have to. next question will I need to lingthen my drive shaft?
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    yes and yes
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    The flip is going to give you 4" more lift for a total of 12".
    New shocks and driveshaft will be needed as well as something for the front end and steering.
    If you want to stay at 6" of lift get the 4" shackle flip and 3" springs. This will net 7" of lift but will look correct and not look like the vehicle has the saggy butt issue.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    You have a 6 inch lift on it now. It doesn't have to require new shocks and driveline if you are able to keep the same height. Is the lift all springs or do you have blocks?
    Based on the previous posts, you'll need new front springs to account for the additional height of the rear.
    I'm throwing a flip on mine (when I have time), I will remove the 4" blocks and keep the same height.
