flip kit
Discussion in 'OffRoad Design' started by 90blzr, Mar 27, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I am going with an 8" lit and have had people telling me to go with The 4" shackle kit in the rear nd 4" springs for a better ride. will the shackle kit be fine for driving on road quite a bit. Are they just as stable as an 8" spring or better even? Any advice would help. Also I have read somewhere, can't remember where, that it would be better to go with a 56" rearspring and move the shackle back farther. I have also heard to get front springs with an offset center pin to move the tire forward in the wheel well so it doexnt hit the back of the wheel well??????? What about the rear shackle moving the tire forward in the wheel well????? Any advice?? Do I sound confused yet??
  2. BMRCCR
    BMRCCR Registered Member
    Mar 7, 2001
    33
    4" filip kit + 4" springs would be better than 8" lift springs. Going to 56" springs wouldn't give signifigant performance increases IMO, but is not difficult to do. On a shackle behind the axle the tire will move toward the shackle upon compression, in almost all cases.
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    A longer spring will give a better ride and more flex on the trail, something I'm considering after I'm finished playing bodyman...
    I'd definitely go with a 4" shackle flip and 4" springs over an 8" spring anyday, I don't think there would be any driveability issues with the flip kit.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    you're on the right track with the 4" spring and the flip kit. It should be a lot better ride and more trail flex than an 8" spring. The deeper the "U" in the spring, the worse off you are.
    There won't be any problems with the flip kit on the street. You're biggest change is going to be the ride height, and that's the same no matter how you lift it.
    I wouldn't go to the 56" spring, even though it's not difficult, you're not going to get much of a gain for the extra work and cost of the spring. If you want to do a custom spring, make it as long as you can fit under the truck, or you can customize the length to work better with your tires and fender wells.
    For the front, most spring makers just put the center pin in the center and call it good. If you want to move it forward, you can use an offset leaf (secret weapon to be announced later) to move it forward. Or to move the rear axle back. Beware that moving the front axle forward will tip the pinion down and may cause some drive shaft difficulty with an 8" lift.
    Making the world better, one truck at a time.
    SW-ORD
  5. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    Stephen - can you tease us like that??? [​IMG]
    Now that you've mentioned the offset leaf - you gotta tell us the details! [​IMG] I've been thinking about this for a while, but of course I want to learn from your experience and expertise.
    Seriously, I want the move the front axle forward and rear axle rearward on my K5.
    Thanks!
    Richard
    Raleigh, NC
    '90 K-5 Blazer - stock, daily driver
    '76 K-5 Blazer - 14-bolt FF, 4.10's, locked front and rear, 36's, SM465/NP205
