Flip shims?
Discussion in 'The Garage' started by justhorsinaround, Dec 11, 2004.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Prolly been asked and answered a couple hundred times but since I'm a dumba$$ I've missed it but where do they go? Between the spring perches and the spring or just where?
    Thanks in advance good folks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Flip shims? Are you talking about the tapered shims to correct pinion angle? If so, yes they bolt to the spring pack(with new center pin) and go between the spring pack and perches.
  3. justhorsinaround
    Sep 16, 2003
    6,798
    So's I have to go buy a longer bolt and good to go yes?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Allan , those shims I gave you won't work like that , a longer bolt is good idea so it goes through and into the perch , they are just the slip in there ones , for 12 bucks thats waht you get . If you had REAL tapered shims ( just like zero rates ) they would bolt to the pack :k5: :k5:
