Flipping a Dana 60
Discussion in 'The Garage' started by sled_dog, Mar 7, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    If I flipped a Dana 60 and put Reverse Cut gears in it, would it work right? I know oiling would be an issue, but that can be dealt with. My mind just farts out on me when I think about the directions and whether you are running on the coast side or proper side. I'm talking in Rear applications by the way.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    No. If you flip an axle, it puts the pinion on the wrong side of the ring gear, and it will go backward.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, reverse cut or not, wont work.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Reverse cut doesn't mean reverse rotation. It means that the gear is cut backward so that when you are moving in a forward directoin you are not running on the coast side of the gear which is weaker then the other side.
    Harley
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    could get a HP D60 center section out of like a ford and use that
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Do it and just run Reverse for forward and Forward for reverse and you are golden! :grin:
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Get a reverse rotation marine engine, that'd make it run the right way. :D
