floor boards
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudfreak, Jun 2, 2001.
  1. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    Where is the best place to get a whole new floor to replace my wholy one? Should I look for a "tub" or a whole body, or maybe order the panels from Whitney( heard it takes for ever). Any other suggestions?
    [image]http://www1.eboard.com/eboard/boards/9/50/68/tink/att-312393/88K5.gif[/image]
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Depends on how "wholy" it is. The Whitney ones will work. You can lay them down ontop of what you have and take weld them in, or you can cut out the old. The problem with laying the new ontop of the old is the old rusty stuff will eventually contaminate the new. So you would need to put down a "THICK" barrier of sealer to slow this down. The whitney ones will fit, but they will not be perfect. You have to bend them and tweek them a bit.
    Hope this helps. You can also order floors from LMC.
    <A target="_blank" HREF=http://www.lmctruck.com>http://www.lmctruck.com</A> it may be lmctrucks[​IMG]
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  3. Mudfreak
    Dec 16, 2000
    116
    NY
    Thanks ftn96 The LMC was something I was not aware of. I'll check it out. I am planning on replacing the old floor with new instead of just covering it up. It's gonna be a big job, lots of fun .
  4. 1big78k5
    1big78k5 Registered Member
    Apr 1, 2001
    92
    moosup, ct. usa
    You can get an original Rear floor pan complete with all the crossmembers from GM. It covers the whole rear floor and runs about $400.00
    '78 K5 SB400, T350, NP203, 35" Swampers
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Depending on just how bad your floorboard is, you may look at por15.com and buy the paint, patch, and reinforcing stuff they sell. I have personally used the patch and POR and it is great. For $100 you could have problem solved, permanently.
  6. stickman2wd75k5
    stickman2wd75k5 Registered Member
    May 11, 2001
    6
    I am replacing my floor boards, cab supports, and rocker panels on mine right now. I have been real happy with the stuff from LMC, especially the rockers. The floor pan repair sections aren't in yet, but they seem to have a small fit problem by the kick panel. There is a little gap (about 1/2 inch or so) between the panel and the kick panel. I am hoping this will fix the major door and windshield sag I had, but it looks I will sitll have to put in about 3/8 inch of shims between mount bushing and cab support. I was hoping that the new parts would eliminate it all but not so. Anyone have experience in this area?? Hope that helps a bit on your question.
