Floor Leaking, Recommend Good Sealant
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BrianDamage, Mar 8, 2003.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    Noticed my carpet getting wet lately...pulled it out today and I'm getting water in where the fender wells and the floor pan meet. What's a good sealant to use on this? I am thinking about Herculining it afterwards, but want to get it to stop leaking first
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Permatex makes a really cool product called "Flowable Silicone". It's designed for windshields, but I think it might work for your application because it is fluid enough that it will seep into voids before it starts to cure.
    It might be worth looking into, brother......
  3. BrianDamage
    May 14, 2001
    753
    Alabama
    do you think it would be better to try and get the old stuff off if possible? Looks like that would be a pain, but I'd hate to not take it off and have to redo it later on /forums/images/graemlins/confused.gif
  4. Can Can
    15,552
    136
    I've used the stuff on the windshield of an old Ford I used to own. I tried to silicone the sucker a couple of times and finally got good results with the flowable stuff. I never bothered removing the old silicone before I applied the flowable, and it worked fine.
    Like I said before, this stuff settles into low spots and voids so if there's a leak it'll find it whether there's old silicone present or not. I personally wouldn't bother stripping the old silicone out........
  5. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Depends on how big the area you need to patch up is, but some JB weld would be perfect. It dies super hard and is very bondable to pretty much any clean surface. I think you can pick up a package of "JB Quik" at any parts store for around 5 bucks.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3M's # 5200 is used for underwater marine applications and will seal anything!!
