Floor shifter cable install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, May 31, 2001.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am going to install a floor shifter but I can not figure out how the cable activates the transmission. The cable looks like it works similar to an e-brake cable but where would it mount to? Would a bracket have to be installed? Does anyone know how these things hook up? I have emailed B&M but no responce any one know how thses things install? I want to know what I am getting into before I shell out the cash
    Brent
  2. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I have installed one on my nova. They work quite well. The bracket bolts to a couple of the pan bolts. They work great, I have a b&m quicksilver.
    eric
    Hell, it don't really matter....it's just for my race car.
  3. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I installed a B&M light truck megashifter in my 84 K-5. The cable mounts between only the shifter itself and the gear selector on the trans. The rigid-ness of the cable pretty much keeps it suspended. You just have to loop it between the trans & T-case. Then, bolt it to a bracket that uses stock trans pan bolts.When I get my "84 build up" camera developed, I could show you. But right now, that's the best kinda description I can give you
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
