Floor Shifter... who's done it?
Discussion in 'The Garage' started by savagek5diesel, Feb 11, 2004.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    Floor Shifter... who\'s done it?
    I want to put a hurst or b&m floor shifter in my 83 jimmy but i have yet to see anybody else thats done it and i want to know what the pro's/cons of it would be. Also what problems might i run into. I know one might just be finding room on floor for it.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: Floor Shifter... who\'s done it?
    Like this [​IMG] [​IMG]
    Bill
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've just bought a B&M light truck Mega Shifter from Summit. Haven't fitted it yet as I've still got the manual trans in and am rebuilding my auto. The kit looks REALLY complete! I've never seen so many brackets and bits. They reckon you can fit them almost anywhere...and I'm inclined to believe them! I don't have a fitment/space problem as I've removed the centre box, fitted recling bucket seats and full harnesses so I can have the shifter close to hand. Otherwise I think you'd have to have it mounted to the left of your t/case shifter. Shouldn't cause a prob tho. It's got a tall base and with spacers and stuff you should be able to mount it within easy reach. /forums/images/graemlins/thumb.gif
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Oh, there you go...Bill beat me to it with pics instead of my garbled words!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thats too funny /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    I can't spell either! /forums/images/graemlins/confused.gif
    Bill
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It may look badly spelt to you...but I'm English and I'm allowed to spell like that!!!! /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. bnc04
    bnc04 Guest
    I just put the quicksilver in my 88. I added a 1/2 inch pine board to the base for a little extra height and I also trimmed a little off the base so it would fit a little closer to the xfer case shifter. Pics of it finished are in webshots. I'm a pretty short guy and it fits comfortable for me, no leaning to shift at all.
    Brett
  8. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    Bill [/quote
    mine looks the same as in this pic but I didnt use the plastic cover or the boot just the shifter maybe I should add them to make it a little cleaner.
  9. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Hey Brett,
    [Hijack]
    I saw that tranny temp gauge mounted in your dash in your webshots...i had given up on that idea bc i thought it just wasn't possible. Any specifics on how you did it? What guage / any particular problems?
    [/Hijack]
  10. bnc04
    bnc04 Guest
    Well, I had that guage for over a year before installing it. I "think" it was 2 5/8's autometer guage. All I did was took a Die grinder with a abrasive cone pointed stone and started to grind away at the bezel from the outside, It actually melted as it ground. I went through the lens, and the black plastic behind it, Some Wallowing was needed ro make the back of the guage fit in there. The guage is just pushed in there and fits very snug with the silver portion of the dash. There was a rubber band around the guage which when twisted in there will not allow it to slop around and I would have to push it out from the back if I wanted to get it back out. Sorry I can't be very clear, It was a while ago but it was pretty easy to do actually. Hope that helps. Let me know if more questions.
    Brett
  11. B_to_C
    Jan 15, 2003
    1,861
    Thanks /forums/images/graemlins/thumb.gif
  12. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    Thanks for the pics and advice guys. It's helped a lot.
  13. Ryan B.
    Jul 18, 2001
    5,693
    CA
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Bill
    Do you have abnormally long arms or something? Bending over to shift would get real old real quick. I take it that you've got an automatic valvebody?
  15. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have a B@M prostick In my truck. Built a pedistal from some steel to lift it up a couple Inches. I can reach it now. It was in my other truck. It broke the column shift (rotton body flex!) And now, In this one.
  16. Arrow
    Arrow Newbie
    Mar 16, 2002
    Has anyone tried to use a cable from the columm to the auto trans??
    I want to eliminate the frame flexing from shifting, without going to a floor shifter.
  17. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    i installed a new b&m megashifter and hated it! hard to adjust the install insn't hard i was not happy the way the reverse lockout felt. i just installed a art carr gate shifter what a difference! do your self a favor and spend the extra hundred bucks if you are stuck on a b&m i have one cheap! just my 2cents
  18. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Bill
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif No just normal arms and I don't have shift kit in this one, But its not a bad reach.
    Bill
  19. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    [/ QUOTE ] you can buy one form summit for $99.95
    part#
    LOK-ACA-1804 2" GM column shift linkage kit
    LOK-ACA-1805 2.25" GM column shift linkage kit
    Andrew
  20. Arrow
    Arrow Newbie
    Mar 16, 2002
    part#
    Andrew
    Thank you that is exactly what I need.
    My new exhaust will run smack into the existing linkage.
