Floor shifter?
Discussion in 'The Garage' started by Bullet, Mar 15, 2003.
  1. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Saw a Blazer today that was an auto w/ a Hurst Floor shifter. Looked awesome and was easy to reach without bending over too or at all to shift. I'm sure that it WAS NOT a manual valvebody. Has anybody done this or have pics and info on it??? /forums/images/graemlins/ears.gif
    BTW, I have a 700R4 tranny with a stock valvebody
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    a friend of mine did it in his 85 f-150 if i remember correctly it was a megashifter for a truck
  3. Phreak480
    Phreak480 Registered Member
    Dec 13, 2002
    36
    dix hills, ny
    I have the truck megashifter in my blazer and i love it
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I installed a floor shifter in mine. It was easy to install and is easy to reach....hold on and Ill take a picture of it.
    Thats the best I can do tonight. I still have to install the trim. Its a z-gate shifter and I will never own another one, they suck for wheeling/street use.
  5. burban33
    burban33 Registered Member
    May 2, 2002
    33
    Georgia
    I have the B&M Quicksilver right beside my seat in easy reach. I am building a center console around it so no pics yet.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I really like the B&M Starshifter. They look just like the Megashifter, but are more street friendly to use. B&M Starshifter
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have the Star Shifter which I am installing in the next day or so. Trying to find some brackets to adapt a cable shifter. They were very common on Firebirds and Camaro's.
  8. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    How hard was it to convert from the column shift? I'm interested.
  9. burban33
    May 2, 2002
    33
    Georgia
    They are very easy to convert. Basically mount the shifter, run the cable, and pull off the old linkage.
  10. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    tempting...but 161 bucks...hmmmmmmm
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Did you leave the stock column shifter in place? Or did you modify to control the radio volume or something?
  12. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    It is a simple bolt on installation. You have to remove 2 transmission pan bolts and install a bracket to hold the cable. Then drill a 1" hole for the cable to go through and 4 bolt holes for the shifter its self and then adjust the cable. The stock shifter arm is held in place by a pin that can be driven out with a drift and hammer. I hooked my reverse lights up to some rear facing flood lights and run them off of a toggle so I dont have a reverse light wire hanging around, but it comes with a switch and you could hide the wire under the carpet if you have carpeting (unlike me /forums/images/graemlins/grin.gif )
  13. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    Doesn't really server a purpose other than looks, does it? I still might do it, but not this week...Anybody think of another reason?
  14. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I have a manual valve body so I have to use a floor shifter. For a more normal vehicle the floor shifter does the same thing as a column shifter but looks better IMO.
  15. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    I have buckets, so I'm not losing leg room...only problem I see is reaching around it to get to the transfer case shifter.
  16. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Less linkage to deal w/ during a body lift, assuming the new new shifter controls the trans and not the stock linkage. The stock floor shifter on my old M/C SS just worked the normal column linkage, what a waste-typical GM /forums/images/graemlins/rolleyes.gif
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It does serve a purpose, but how much depends. Shifts are more positive. You get features like reverse lock-out and such so you don't miss-shift when in panic mode. You can change shift paterns like reverse-manual valve bodies. And probably most important for GM's flexy frames, you have less problems with getting it into the right gear, and keeping it there. With the column shift, the flex can be bad enough (especially with bad mounts) to actually change gears on you or even bind it up till you can't shift at all (or so I'm told, never experienced that one).
  18. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    YAY, arguements for the plus side!! Damn, I guess I just HAVE to do it now. Ain't that a B!tch?
  19. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    The starshifter won't work with the 700r4...so I have to go with the B&M Light Truck Megashifter...seems to be my only choice.
  20. burban33
    May 2, 2002
    33
    Georgia
    Check out the Hurst Promatic 2
