Floppy tilt steering
Discussion in 'The Garage' started by frickenwirthless, Jul 9, 2005.
  1. frickenwirthless
    frickenwirthless Newbie
    Jun 29, 2004
    Lewiston, Idaho
    So, my steering wheel has gotten progressively sloppier, and now it's to the point that you can push up and down on the steering wheel, and I get like 3 inches of travel. I read in a 4 wheel drive magazine that on dodge trucks and suvs they had this same problem, and all you have to do to fix it is take it apart, and throw some lock tight on the bolts that hold it together and it's fixed. Is this true for my 88 suburban tilt steering wheel? Anybody else experienced this?
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  3. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    yea thats the tickit but dont wait to long or the ends will break off and the screws will not tighten :hack:
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    the common fix is to locktite only the 3 bolts you can get too. The fourth is virtually infreakinpossible to get too, PLUS, they are inverted torx heads so you'll have to buy some special tools, unless you happen to know ME really well. (well enough to "borrow" my NOT LOANED OUT TOOLS!) :D
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I personally tighten all 4, not impossible to get to if you use a pivot pin puller to take the tilt head off, and a regular 6 point socket will work to tighten them if you don't have a inverted torx
