flow kooler water pump disc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jan 2, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Has anyone tried this? Its a disc that you put on the back of your water pump impeller and is supposed to increase flow by up to 60%. It $6 from the summit catalog so if it works it would be a cheap cooling system upgrade.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. dyeager535
    26,979
    Haven't known any one to actually run it, although its been talked about on the car lists off and on. If it boosts the volume of water you are sending though the system, as it is supposed to do as I recall, it will help.
    Dorian
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
