Flow Tech headers??
Discussion in 'The Garage' started by Storm24m, May 16, 2002.
  1. Storm24m
    Storm24m 1/2 ton status
    Mar 12, 2002
    148
    Knob Noster, MO
    Anyone ever hear of these or have them? They came with the blazer when I bought it (uninstalled) I was just curious about their quality and if they are worth installing. They look sorta cheesy.
  2. Storm Trooper
    Nov 24, 2000
    4,640
    I have them and they work just fine for me. They are made by Holley and if you want to check out more info on them go here.
    <a target="_blank" href=http://www.holley.com/HiOctn/ProdLine/FlwTech2.html>FlowTech</a>
    Unlike some other Chesey headers, they don't hit the shackels.
    BTW, If you don't want them, let me know.
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'm running a set of the flow tech's on one k5, and hooker super comp's on the other. paid a little over $300 for the hookers (no ceramic coating), and under $200 for the flow tech's with ceramic coating.
    if I had it to do all over again I'd go with the flow tech's - hookers a great, but I don't think they extra cost is worth it. the flowtech's are wearing like iron, and really don't have any problems.
    one warning - the flow tech's will not allow you to run a full size oil filter with the factory oil cooler if you have one. I just got replacing the engine in Darth Blazer because a factory cooler line broke, and so I don't care about that little issue.
  4. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I have the ceramic flowtechs. they look and work very nice, nice thick flanges (I think 1/4") My one problem/ complaint is that the passenger side collector hits my bottom shackle bolt /forums/images/icons/frown.gif . I think longer shackles will fix this, but it shouldnt be that close. IF they are just the painted steel ones they may not have the thicker steel and flanges.
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    my hooker supper comp's hit the bolt of the shackle on the right side with the longer entended shackes - had to cut it off &amp; grind a touch. on a stock suspension (hand had 3-4" of lift before I put it back to stock) I have had no problems with the flow techs' hitting the shackles.
  6. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    i had the asme problem with the shackle bolt. i just took it out and turned arround so the head of the bolt was on the inside
  7. ChevBlazin
    Feb 4, 2002
    332
    I did that too, but the head still hits. kinda too close for comfort. oh well
  8. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    i have the flow techs and ive ran them for about 5 yrs now and have had no prob. i have the flowtechs with 2.5 inch pipes on 40 series flowmasters with dumps and it sound great and the performance is there
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I've got the ceramic coated ones too and I love em. My drivers side collector rubs on one of the spring clamps at full stuff but I think thats because my engine mounts are totally shot so the engine is pretty much down on the frame. Once the new mounts go in it should be fine.
    The headers made it through a NY winter without ANY signs of rust what so ever so I'm impressed. (I wish I could say the same for the rest of the truck!) /forums/images/icons/laugh.gif
