Flowmaster for 88 sub
Discussion in 'The Garage' started by Hobbs, Mar 28, 2006.
  1. Hobbs
    Hobbs Registered Member
    Feb 28, 2006
    28
    Alabama
    I have a 7.4 3/4 ton 88 sub and I want to add a flowmaster cat. back exhaust.
    When I spec out my truck on varies web sites I get a system that matches everything about my truck except the engine size. They say it fits a 5.7L and makes no mention of 7.4L. Is there a difference between the 5.7 and 7.4 from the cat. back that I should worry about?
    Attached example.
    http://www.autoanything.com/products/product_mv.aspx?p_id=2111&se=flowmaster_force_ii_exhaust_system___single_side_exit
    Thanks,
    Hobbs
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    If the system fits your truck it will work, if its a 3" exhaust it doesn't matter unless you are running over 300 hp
