flowmaster ticking?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Schwabie, Feb 21, 2003.
  1. Blazer_Schwabie
    Blazer_Schwabie Registered Member
    Feb 21, 2003
    15
    Washington state
    I just got a 40 series flowy put on my rebuilt 350cid motor and it ticks like a leak or something. I just had the muffler switched to a new one,to see if that was it, it wasnt.Could it be my air/fuel mixture is off? /forums/images/graemlins/1zhelp.gif The carb is fairly new (yr old) edelbrock 600cfm auto choke.If you could give any help at all to fix the noise it would help. /forums/images/graemlins/thumb.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    when I shut my truck off my cats usually make a ticking noise. My mufflers might too, but I know my cats do if they are hot.
  3. yotapunk
    yotapunk Registered Member
    Jan 3, 2003
    23
    southern CA
    MIght you just have an exhaust leak somewhere? I know when I just got my flowmaster put on the tech (after the truck was in the air) tapped my catylitic (sp?) and dust or carbon whatever you want to call it came out of 3 hole which he welded up.
    Good luck
  4. Blazer_Schwabie
    Feb 21, 2003
    15
    Washington state
    it only ticks when its cold then when it warms up it sounds awesome. it is annoying and i wanna know what is causing it /forums/images/graemlins/1zhelp.gif
  5. Blazer_Schwabie
    Feb 21, 2003
    15
    Washington state
    no cat either /forums/images/graemlins/cool.gif
  6. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    It's probably the pipe expanding due to the heat building up. Does it tick while it cools down too? Can you hear it over the exhaust tone? Is it at the muffler, manifold/header, or towards the rear? Check your hangers and make sure they are not in a bind or or too loose.
    I would not think it is in the muffler. I have had many flowmasters and have never had any internal problems with them.
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Ditto I have 2 sets and haven't had this problem /forums/images/graemlins/truck.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That's good. I would say if you had a cat in there it would howl and scream like mad. Until dead that is... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sound like it could be a exhaust gasket. If you have a gasket that is going bad, it will tick untill it gets hot and expands. Try tightening all the exhaust bolts first, then check for bad gaskets.
    Dan /forums/images/graemlins/burb.gif
  10. scott leckie
    scott leckie Registered Member
    Feb 15, 2003
    5
    I had a 78 F150 with a cold ticking problem. Turned out to be a wrist-pin problem caused by the break-in after an expensive rebuild. I was pissed!!!
  11. Blazer_Schwabie
    Feb 21, 2003
    15
    Washington state
    could it also be the new tail pipe? i heard there is like a lip at the end that will make it tick. there is alittle lip at the end of the pipe where it was cut, but why would it make it tick? /forums/images/graemlins/confused.gif
