Flowtech Headers
Discussion in 'The Garage' started by BlackDog714, Mar 31, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Afterburners??? Are these things any good? $136.99 at Jegs.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    From everything I have ever heard about headers, cheap headers suck. I know a friend who had Flowtechs and he hated them. Blew out collectors every 3 months or less.
    I bought a set of flowtechs used for my truck and then found out about them. I am still running stock manifolds if you get my drift.
    Harley
  3. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    I got a set of the flowtech afterburners, i like them i do have problems with the collector gaskets but the people that did my exhaust did not set the flanges correctly so the one side i had to double up the gasket, havnt had any problems since.
  4. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    i've been running them since early last summer and have had no problems with them as of yet. {knock on wood} i actually just took them off to spray some ceramic hi temp paint on them, to combat the rust from the New England winter. No complaints for the price i paid.
    Nate /forums/images/graemlins/k5.gif
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Got them in Ceramic...'bout 5yrs or so...changed a gasket about 2 yrs ago...never have changed a collector gasket...ceramic is holdin' up pretty ok and I do drive gravel quite a bit...no complaints for the price...worst luck I ever had was with Hedmans...wouldn't waste money on those again...I like Hookers also, just a little more cash...I bought the Flowtechs after reading an article in Peterson's where they said some pretty good stuff about them as far as getting to plugs, fitment, etc....I'd buy 'em again....the next step up I would consider would be the Hooker Pro Comps w/ Jet Hot Ceramic coating....Ask 20 people and you'll prolly get 20 different opinions....buy what you can afford, I seriously doubt you can tell the diference in the seat of your pants... /forums/images/graemlins/waytogo.gif
  6. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Those are the same ones I have...that gray coating has a disclaimer that it's only to prevent rust during shipping. NOT fun to remove, and mine are rusting following my autozone header-paint job.
    Gonna cut the flanges inbetween the tubes this week and put in some exh manifold gaskets. Maybe it'll hold this time. /forums/images/graemlins/whistling.gif
  7. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I've had mine on the Suburban for a few years now and the only problems I've had were with the collector gaskets and the manifold flange bolts. Replaced the collector gaskets with soft aluminium and the have held up for a year and a half so far (almost 60k miles). The manifold flange bolts didn't line up "perfect" so I had to hog one out on the passenger side. Trimming the webbing between the ports would likely correct the problem as well. /forums/images/graemlins/hack.gif I'm going to trim them anyway when I freshen everything up this summer.
    The grey paint they put on them was gone as soon as I got my cam broken in (about 20 minutes) and now they look like rusty headers /forums/images/graemlins/rotfl.gif but they work fine.
    My nephew recommended them and told me that the single pipe exiting into the collector would soften the sound a little. It does sound better than it did with the POS Hedmans that the PO had on there ... but I also replaced all the pipes and rebuilt the engine.
    I think I paid about the same price for mine from JEGS.
    Best set of cheapie headers I ever bought. /forums/images/graemlins/thumb.gif Next time I'm springing the extra cash for the ceramic coating.
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    mine have worked fine for 4 years now.rusty as all hell but they work.i didnt use the collector or manifold gaskets they gave with the headers.they would have blew out in a couple of miles.i use rol high performance gaskets at the collector and the head and havnt had to change thm since i put them on.
