Flowtech Warlock Mufflers vs. Flowmaster 40 Series(PIC)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Aug 22, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The warlocks have a removable cap on the end for open exhaust, I like the sound of straight pipes so I figured these would kick ass. My question's are will they leak a lot? And will the cap get hard to remove after a while(ie weld itself on) Also would these be louder or quieter than 40 series Flowmasters??? Here is a pic<a target="_blank" href=http://www.jegs.com/photos/38750552.jpg>www.jegs.com/photos/38750552.jpg</a> Thanks
    ~~'84 K5~~
    Check it out at:
    &lt;a target="_blank" href=http://www.k5.rockcrawler.com&gt;www.k5.rockcrawler.com&lt;/a&gt;
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I heard those caps get realllllll hard to take off after a while. And that comment was from a carguy. Think how much worse it would be on a truck that sees mud, water, dirt, etc. I love my 2 chamber Flowmasters...when they wear out I'm going to buy the same thing again.
    '73 K5
    Chevy good...Ford bad
  3. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    im with 73 im hooked on my dual chamber flows
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), Dana 60 465, 38.5 swampers
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I love my Flows, but I've been threatening to put the Warlocks on for a while myself. I've also heard that you have to make a weekly ritual of silicone spray on the caps or else they'll never come off.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I have a single 3" in 3" out 40 series delta flow and i love the way it sounds at all rpms. It sounds really cool when u rev it up under an overpass. Ohh man it growls!!! Plus its not that loud on the inside especially once it is into overdrive.
