fluctuating idle speed.....
Discussion in 'The Garage' started by hi pinion, Apr 3, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    my truck has a mind of its own.....when i start the thing,it idles real high(choke) i know this is normal.when i hit the gas slightly after warm up,it will go down a little,but its never quite right,it always seems to fast.However,once in a while it will go way down,to a nice idle witch seems normal.I was thinking a loose distibuter??I dunno,help...oh,its an 85,with all the old Atari type computer stuff.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like a vacuum leak
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I concur, vacuum leak. Lookat the simple areas first. Tighten carb and intake bolts. Then start checking hoses etc /forums/images/graemlins/k5.gif
  4. hi pinion
    Sep 25, 2003
    5,354
    yeah it does have a once in awhile BACKFIRE when i shut the truck down.....could this be internal carb problems???someone looked at the carb not too long ago,and said i needed new bushings or seals inside,and that what was causing the backfire/vacum when i turn off the truck.i JUST got through re-doing the intake gaskets too,like 2 mo ago.??????what is the obvious???since i JUST re did the intake???
