fluid at joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Sep 28, 2003.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    this is the front of my rear drive shaft. i am leaking fluid from inside the u joint. i am certain that the fluid is not coming from where the yoke enters the transfer case - you can see that the yoke shaft is dry at this point. i understand that the u joint caps are filled with grease; but this is more than excess grease. it is generating enough oil/fluid to throw onto the underbody. where is this coming from and what can i do to fix it??? thanks
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hmmmm....what color is the fluid?
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    been wheeling lately? stuffed that driveshaft into the tcase?? i bet its tranny fluid, what does it smell like?
  4. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    dark fluid - like oil. definitely coming from inside the joint.
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I noticed its a greasable joint... quite often longer drives will get that grease nice and warm... allowing it to come flyin out of the caps. I'd bet that if you cleaned it off, you'd probably find that it has already stopped "leaking."
    The other obvious sign here is that this joint is close to grenading on you! I'd get the rear of the truck off the ground, and check that joint ASAP! I hear it sux to blow one on the way to work in the morning! /forums/images/graemlins/rotfl.gif Good ol AutoZone can sell you nice solid models for something like $13ea.
    Good luck.
    -Dan
