Fluid Capacities
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jul 17, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What are the fluid capacities for an 700R4, rear 10-bolt and NP208? Thanks for your help.
    YEEEEE HAWWWWW[​IMG]
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    700R4=5 qts Rear 10 bolt=2.5qts NP208=I have no idea
    90K5
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    No way the 700r4 is alot more than 5 Qts.
    Maybe you mean when you do a filter change.
    The real FACTS will follow I hope.
  4. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    What about a turbo 400 when changing the filter?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The 700R4 is 5 qts. becausae when i added my deep pan I put in 8 and its supposed to add 3. This is w/o changing the fliud in the torque converter and with a filter change
    90K5
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Factory manual says:
    700R4... 10 pints (5 qts.)
    208..... 10 pints
    Rear end depends on the ring gear size...
    8 1/2"=4.2 pints
    8 7/8"=4.5 pints (3.5pts 80-82)
    9 3/4"=6.0 pints
    10 1/2"=6.5 pints (7.2 for Dana)
    12 1/2"=26.8 pints
  7. Executioner
    Feb 22, 2000
    1,530
    I thinks you are missing some words.............
    Like the refill capacities when you do a filter change on the 700r4.
    The TQ Conv. and the Tranny, have a capacity or over 20 pints(10 qts.), and I don't think the TQ Conv. will hold
    10 pints (5 qts.) !
  8. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Because the torque converters do not have drain plugs anymore makes it a moot point. When you pull the pan and refill, it takes 5 qts. I just did this prior to driving to Virginia on vacation. 5 qts to fill it. So says Chiltons, GM factory manual and me....
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Executioner,
    Why do you ALLWAYS do that??
    You and that word 'Facts'!
    I ain't tryin to cause an argument but you ALLWAYS do that!
    What about the facts!, Why??????
    And the way you say it, man it sounds like you want to go out and kick the neighbors dog or something.
    Be cool man we are all a happy family here.
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  10. Executioner
    Feb 22, 2000
    1,530
    Hey that's fine by me ! But your mixing 5 new qts. of tanny juice with 5 qts. of old tranny juice.
    That's like changing your engine oil, and not changing the oil filter, sort of anyway............
    Let me state it a differnt way the capacity of the 700r4 system is like 10-12 Qts.
    I think this is correct.
  11. Executioner
    Feb 22, 2000
    1,530
    Because if it not stated as a FACT, or an opinion, then what is it ?
    Why do pleope asnwer a ? with an opinion and or experince, and don't tell the reader that ?. Is it implied that all
    answers are opinion and experice ? I want Facts to the answers, research, data, not guesses, verifable so
    if I have that perticualr Blazer in my garage I know for a fact that it is the correct answer. If you don't have that answer just say so, You and I know that GM may have done things differntly in the 60-70-80-90's say so, like your milage will very,.... ect.
    Be as specific as you can to answer the ? If you use word like "all" be prepared to back it up.
    Sorry that I can't exspess my self to well of the internet, my grammer and spelling suck, I will be the first to admit
    that.
    Please don't take this the wrong way, it's not intended to flame anyone.
    I will be happy to discuess this with anyone, almost anytime............
    Thanks alot
  12. Burt4x4
    6,854
    I don't mean to steer away from the topic of this thread but just to reply to the Executioner I think all message boards are considered a great way to get others opinons and or experinces on certain topics. Facts are just raw data with nothing attached to it. If fact finding helps you assure your self that the opinon you just were givin is accurate then by all means whip out that specifications book and look up the raw data/facts.
    Speaking for my self I get further on opinon and experiances than facts. Reading a manuals interpetaion on how to perform a task, to me, is MUCH harder than having a bud tell you how he did it with out any negitive results.
    Everyone is different and I respect your opinon as much as the next guy! [​IMG]
    I do learn from facts but they are mostly forgotin and the experiance is rememberd.
  13. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Executioner...you are the main reason I don't say much on here anymore, you argue about everything like nobody knows anything but you. Everytime I see a post from you I know you are going to ask a question then argue with each and every person that gives you an answer. If you know so darn much, why ask questions?
    I have gone through every book I have , even the factory manual for the 700R4, the REFILL quantity of Dextron is 10 pints or 5 quarts. Call any tranny shop they will tell you the same, REFILL is 10 pints. The only way to drain it completely is to remove the tranny and converter. Course knowing you , you would probably lean the Blazer against the garage on it's tailgate just to prove a point....
  14. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Eagle - what's the ring gear size of a stock 10-bolt? 8 1/2 or 8 7/8? I have a 84. Thanks a bunch!
  15. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    To be honest, I have no idea. But I am sure there are others here that know it right off the top of the head. Or I could search through the book and find it for you.
  16. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    No problem, I don't need it that bad, I was just curious, thanks.
  17. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I will probably look it up, as now you have me curious. Let you know what I find...
  18. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    4x4Blazer...sorry dude I forgot about you...the turbo 400 REFILL is 7 pints, 1985 only it is 9 pints. And that is according to Hoyle...errr Chiltons..
  19. Executioner
    Feb 22, 2000
    1,530
    Well sorry you fell that way. Back to the original post, what are the capacitires for 700r4.... ect,
    In the original post I don't see the word REFILL, thats the only FACT.
    There is more than one capaitiy.
    Later
  20. det45
    det45 1/2 ton status
    May 23, 2000
    112
    San Antonio Texas
    All you all need to relax man.....All opinions are good and it's up to the reader to decide what's fact from fiction...It's all good man....Peace
